2000 CLK430 Oil Change
Old Nov 2, 2006 | 10:31 PM
jakie's Avatar
Default 2000 CLK430 Oil Change
Hello Everyone,
Im gonna finally do an oil change myself. Can someone tell me what type of oil to use and how many quarts? I heard it is mobile 1 and it is 0W40 and about 8 quarts. It this correct?
Is it hard to drain the oil or remove the filter?
Thanks in advance.
Jakie
Old Feb 9, 2007 | 01:05 PM
chochocho's Avatar
Default RE: 2000 CLK430 Oil Change
i am in the same boat. is there a write up on oil change? i am having the hardest time taking the oil filter out. there's a black plastic thing covering the filter, how does this come out?
Old Feb 10, 2007 | 02:56 PM
MBZTech's Avatar
Use mobil 1 and 8 quarts......The black thing unscrews....Usually use a special tool to unscrew it...Im sure you can use an oil filter wrench.....Just have to unbolt the under belly cover of the engine... They are 8mm screws.....Then just remove the drain plug (13mm)....make sure you use MBZ filters...Dont be cheap and buy the paper filters....They become brittle and break..
reza1u
Sep 13, 2008 06:43 PM
rdf63
May 10, 2008 12:29 PM
floresadolfo1
Jan 26, 2007 04:15 PM
cala833
Jan 9, 2007 04:23 AM
RockSolid
Jun 24, 2006 06:41 PM
