A210 auto stuck in 1st gear ESP & engine warning lights
has anyone had this problem ....
A-class w168 52 reg A210 auto stuck in 1st gear will not change up ESP & engine management warning lights on plus gear indicator gone off loud clunk when put it drive or reverse , |
RE: A210 auto stuck in 1st gear ESP & engine warning lights
ORIGINAL: w168 has anyone had this problem .... A-class w168 52 reg A210 auto stuck in 1st gear will not change up ESP & engine management warning lights on plus gear indicator gone off loud clunk when put it drive or reverse , |
Hi there,
I too have the same problem with identical symptoms. I was driving my 2003 A210 two days ago, everything seemed normal till I stopped in traffic. The car refused to change up gear with the engine management and EPS/BAS lights staying on. The display showing current gear selection on the instrument panel also vanished. Did you manage to solve the problem? How did you you go about it. I would greatly appreciate any help with is matter ....thanks |
A210 stuck 1st gear with no gear indicator
I too have suffered the limp mode with W168 (2003 model).
I've had ECU testing try to rectify without luck!. anyone has any info on how to resolve this pb ? tks |
