A170CDi - EMISSIONS PROBLEM. URGENt HELP NEEDED!!!
Old Jul 28, 2006 | 04:20 PM
Raj1's Avatar
Default A170CDi - EMISSIONS PROBLEM. URGENt HELP NEEDED!!!
Hi all
i have a A170CDi auto. It failed its emissions test. The reading should be 2.50 but is 3.20-3.40. Its not out by much but it refuses to come down. I have tried the diesel magic stuff to reduce the smoking which has worked in reducing the smoke to virtually none but the reading is still not coming down.
If anyone can shed some light on as to why i am having this problem, or make suggestions to solve the problem, it would be greatly appreciated. The diagnostics are suggesting that the car is perfect and there are no faults. PLEASE HELP
Raj1
Old Oct 1, 2009 | 02:36 PM
westy1234567's Avatar
Default A class problem
Hi i am new to this so forgive me!!!!!!!
I own a a class 170cdi advantarge auto 51 plate, i have a leak underneath which is not coming from the engine. i think it is the gearbox as when i looked underneath there was oil dripping from a hole about 1/2 inch in dia. the hole is in some kind of housing. when engine is started something in the housing moves around like the clutch/flywheel ?????
I hope one of you brainiacs can help. Thanks..
chalkie
Aug 31, 2011 02:03 PM
bruce110
Mercedes A Class
Jul 21, 2009 01:17 PM
Budvarholsten
Feb 29, 2008 07:37 AM
jd_uk_sl320
Oct 16, 2007 09:55 AM
jd_uk_sl320
Oct 16, 2007 09:53 AM
