A160 central locking problem
Old Apr 7, 2008 | 02:43 PM
b3ts's Avatar
Default A160 central locking problem
[&:]Hi everyone-I'm trying to find out whats up with my central locking. The interior lights won't go off. The car locks and unlocks as normal on the key fob but the internal key button won't work.All the doors all lock as normal when you go over 10 miles an hour but now all the doors have started unlocking when I slow down to less than 10miles an hour. Makes for an interesting journey with the doors locking and unlocking themselves all the time!!/ Thanks anyone if you can give me any ideas
Old Apr 19, 2008 | 06:59 AM
bipin_c's Avatar
Default RE: A160 central locking problem
hiya,
i have a w reg /2000 a170 and have been having similar problems. Wheni try to lock the car with the fob, the alarm activates but the doors dont lock, and so the alarm goes off. But then when im driving the doors lock as normal (when u go over 10mph) and unlock again (as above).
I've had to resort to removing the interior light bulb and disconnecting the locking pump, and manually locking each door with the key. does anyone have any ideas on how to resolve this? is there any way to reset the alarm? I have 2 other small keys a red and black one which i think are forthe alarm but not sure where they go.
Any ideas would be welcome...
Old May 21, 2008 | 07:42 AM
thegov's Avatar
my feyfob wont work at all and so my alarm wont go off when i manuallyopen the door. I have tried to disconnect the battery and also tried the fuses but to no avail. Can anyone help??? I have also took the fob apart but it seems okinside (nothing loose)and it only had new batteries two months ago.
Old May 23, 2008 | 03:00 PM
Arildo's Avatar
You have of course checked something silly like that the door, luggage and hood switches are ok? - This switch signal will go into thecomputer to detect alarm, and to switch on/off the interior lamps.
Old Aug 16, 2018 | 05:58 AM
Jake7000's Avatar
Default Same issue
Hi have the same issue.
Did you end up finding the solution ?
delboy277
May 12, 2009 05:19 AM
FrankB100
Apr 12, 2009 08:15 AM
johngolfer
Mar 8, 2007 03:39 PM
Ponytailbillp
Jan 25, 2006 01:38 AM
shurl
May 24, 2004 09:35 AM
