A150 wind noise
Old Apr 27, 2008 | 12:22 PM
trendafilovmk's Avatar
Default A150 wind noise
I recently bought brand new A150.When I drive over 120 km/hI hear wind noise from the driver's side door.It sounds like driving with open window but everything is well closed prior driving.Anyone with the same problem?
Old May 9, 2008 | 10:46 PM
bazzle's Avatar
Default RE: A150 wind noise
Yes on w169 A200
Noisy arnt they.
Bazzle
Old May 23, 2008 | 03:17 PM
Arildo's Avatar
-Sorry, this is a baby merc, it IS a bit noisy! But if it's too bad, check for twist on the doors/ or bad door hinge(The noise can be from the back door as well). Check the door gasket also. To do this, use an ordinary A4/letter paper to put between the door and car frame - close the door and see if you can pull the paper out without braking it. If it break, the gasket are ok, if it can be pulled out easily, there is a problem with the gasket. Do this trough the hole door frame.
adw2002uk
Jun 20, 2025 01:00 PM
Chris Cooper
Mercedes A Class
Mar 22, 2011 02:00 PM
mini_brabus
Mercedes A Class
Nov 22, 2008 03:20 PM
A150_2005
Mercedes A Class
Nov 6, 2008 10:27 AM
trendafilovmk
Apr 27, 2008 12:26 PM
