Xenon Headlights
Hi fellas, i have a 2004 C230 Kompressor (which i love b.t.w.) but i saw a black one with a Xenon headlight kit. They looked black, does anyone know where i may get my hands on some?, are they
difficult to install?
Hi this looks cool.
I have a C200 yom 2005. Looking to swap to Philips Xenons with ballast. Only changing the bulbs. Is it safe & will it short-circuit the car & case fire? Can someone advise if its safer to chage entore light custer.
It will work but you are most likely to do dealer programming after you install the kit. Our HID kit does not require programming.
ORIGINAL: mbc200
Hi this looks cool.
Hi this looks cool.
#10
That's right. It will not fit coupe. Only solution is OEM bi-xenon headlamps.
ORIGINAL: rafaramirez
I read that these won't fit the coupe, can you confirm that? If not, which Bi-Xenon solution is available for C230 Coupe?
Thanks!
Thanks!
