Wide body fenders
i dont know about any fenders but i have seen some wheel arch extensions that dont look too bad. check out www.overboost.com they might have something for you.
id go for 9.5" wide with 35-40mm offset if you get a 35 offset you may need a 5mm spacer, that should allow you to run 255 or 265 out rear.
you could run 10" with an offset of 35mm, but you would need to attempt to flare the rear guards slighlty to ensure no rear rubbing, or atleast take out the plastic lining and do a bit of panel beating on the inside to ensure no inside rubbing also. with that size rim you wont be able to lower it too much
what do u wana run up front?
thats my 2c anyway
thats my 2c anyway
#9
if you can pull off a 295 in the rear man i will be impressed! without rubbing 235 will really be your limit up front.
but 295 is a bit rediculus unless your c is making like 500+hp why is that necessory?
maby you could tub the rear
![Big Grin](https://mercedesforum.com/forum/images/smilies/biggrin.gif)
#10
A portion of the lip on the front and rear fender have to be cut and some flares need to be molded in. I was hoping to find a one piece after market front flared fender but there doesn't seem to be to much of a selection out there for M-Benz. The car will be built for Auto-X in the future.
