Wheels!
#11
RE: Wheels!
You're not wrong. Its an image thing with no performance improvement. If it was something I wanted to do, I wouldn't go any bigger than 17". You'll fill up the wheel hole some, have lower profil tires but still have some shock absorbing through the tire and probably won't screw up your rims on pot holes.
I saw a W202 with 20" wheels and it looked like a circus car to me.
#14
RE: Wheels!
Has anyone tried having the stock rims polished and clear coated to get a gleaming look without sacrificing performance? I have an SLK320 '01 and am considering that avenue. My car is black. I also considered just painting the wheels the body color to make them disappear. Any thoughts?
#15
RE: Wheels!
#17
#18
RE: Wheels!
first off welcome to the forum jamminj
i run 18s on my 94 c280 and they look good on it. you can run anything from 17-19s relatively easily aslong as there the correct offset for the car they shouldnt rub, especially at standard hight.
it shouldnt effect the spedo as you will have lower profile tires which should have a similar overall diameter to the stock wheels.
ride should be similar, if only ever so slightly rougher (you prolly wont even notice this)
they shouldnt brake or crack unless you hit a massive pot hole which would prolly damage something else anyway.
they will be slightly heavier than the standard wheels so the acceleration will be slightly worse (if traction isnt an issue in either case) but you will have better more predictable cornering due to the lower profile of the tires giving less "tire roll"
brabus makes nice wheels. go for them, 18s generally sweet
19s if you are more serious about modding
heres a pic of my car with the 18s
https://mercedesforum.com/upfiles/42...5ECAF23553.jpg
#19
RE: Wheels!
[/ul]
they will be slightly heavier than the standard wheels so the acceleration will be slightly worse (if traction isnt an issue in either case) but you will have better more predictable cornering due to the lower profile of the tires giving less "tire roll".
I APOLOGIZE FOR VOICING MY TWO-CENTS HERE. AS YOU KNOW, I AM ALWAYS AGAINST MOLESTING OR DE-FLOWERING A PERFECTLY GOOD CAR.
