What Oil
Old 11-13-2003, 11:39 PM
AV8TOR's Avatar
Default What Oil
<P class=Msonormal style="MARGIN: 0in 0in 0pt"><FONT face=Garamond size=3>What oil are you guys/gals using in your C/class Benz and what interval are you changing it?</FONT></P>
Old 11-14-2003, 11:24 AM
Default What Oil
Mobil 1 0W-40 in all my vehicles and I change it at 5k mile intervals along with the filter. Before the 0W-40 came onto the scene I was using Mobil 1 15W-50.</P>
Here's a link to the Mercedes approved oils, notice Mobil 1 0W-40 is one of the few 229.5 oils that are readily available here in the states.</P>
http://www.whnet.com/4x4/oil.html</P>
Old 11-14-2003, 11:57 AM
AV8TOR's Avatar
Default What Oil
<P class=Msonormal style="MARGIN: 0in 0in 0pt"><FONT face="Times New Roman" size=3>Jet I saw that web page before but I was not sure about the numbers under MB. Is the 229.5 a chassis number or oil requirement number? <SPAN style="mso-spacerun: yes"></SPAN>The C230 is a chassis number of 202 and that is not listed. <SPAN style="mso-spacerun: yes"></SPAN>I also get confused when I go to the Mobil 1 page </FONT><FONT face="Times New Roman" color=#800080 size=3>http://www.mobil1.com/index.jsp</FONT><FONT size=3><FONT face="Times New Roman"> <SPAN style="mso-spacerun: yes"></SPAN>and have search oil forthe C230 and itis says there is nograde of Mobile 1for that car.</FONT></FONT></P>
Old 11-14-2003, 12:17 PM
Default What Oil
229.5 is a Mercedes oil specification number. It has nothing to do with chassis numbers. The synthetic vs. regular oil debate rages on in most forums with both sides thinking their oil is the best. As long as you use change the oil on a frequent basis (3 to 5k miles) you could really use any brand of SL rated oil you want. Just make sure the viscosity isn't too high for your climate conditions. I use synthetics in everything, engine, tranny, rear-end, etc. etc. because I run the hell out of my cars and want the extra protection that a sythetic offers. By the way your 98 C230 has Mercedes synthetic oil in the tranny from the factory.
Old 11-14-2003, 12:41 PM
AV8TOR's Avatar
Default What Oil
Thanks Jet Mobile 1 0W 40 it will be then. I might consider some Amsoil down the road, but I will use Synthetic.
Old 11-14-2003, 01:07 PM
Default What Oil
Amsoil is another excellent oil that I've used in the past. Their 10W-30 is hard to beat.</P>
</P>
Try out this website if your interested in doing an oil sample. An oil sample will tell the whole truth as to how your oil and engine is doing.</P>
http://www.blackstone-labs.com/</P>
Old 12-24-2003, 06:34 AM
Default What Oil
too bad redline isn't on their list as approved oil. I run it in my 700BHP car and haven't had any problems.</P>
Sid</P>
Old 12-25-2003, 12:25 AM
Default What Oil
Sid</P>
</P>
</P>
Have you ever done an oil sample on the redline your running? Redline doesn't typically do to well when it comes to iron ppm (parts per million), it's usually quite high......</P>
  #9
Old 01-30-2004, 01:41 AM
Default What Oil
Jet , your right about redline and the tests. I've seen and heard the same.
Kale
  #10
Old 01-30-2004, 10:50 PM
Default What Oil
My MB : Mobil 1, as specified in the manual (0-30 i guess), every 8-10k miles (when the display reads 1500 miles for next oil change). There's a lot of comparable quality material in the thread, and I feel bad I change it less often than the rest!.</P>
SUV andhobby : Quaker State 10w-40 + 1 can stp every 3500 miles, but these are not-so-technically-advanced engines (heck! an allsteel1967 454 V8 with twin 4barrel carbs with screw adjustmentsand no computer!, it can be fixed with duck tape, a screwdriver, a 1/2 in hex key and the pump will not move the oil!) <IMG src=smileys/smiley3.gif border="0">
</P>
Quick Reply: What Oil
