Transmission oil when to change help!!!!
#9
actually mercedes doesn't recommend changing the fluid in that trans. unless there is a problem
Besides that, I've asked around and tech after tech that is knowledgeable about that transmission says to change the fluid. BTW, Sleepwalker (in this thread) is an MB technician and says to change every 60K mi. My mechanic says those who don’t change the fluid are asking for trouble. The worst that could happen if you change and don’t need to is you’ll be out $200. But, if you do need to and you don’t……well, that transmission is a $5,000 piece of hardware not including installation. ($2800 for a reconditioned one.)
