Replace O2 Sensors - 1999 MB C280
I have a 1999 MB C280 and my diags tell me that my "check engine" light is on because my o2 sensors are out. I've found a reputable place to buy the sensors, I just need to know where the sensors are located and how to replace them. I found a source to get an O2 wrench for this model Benz, but like I said - where are the sensors, and what is the process to replace them?
Thanks for the help!
RE: Replace O2 Sensors - 1999 MB C280
They are located on the exhaust manifold, and after the cats as I remember. I think there are 4 or them. Someone please correct if I am wrong. How do you know all the O2 sensors are bad? I had a check engine lite and had to replace one sensor, the dealer did it, I never saw the OBD2 information.
Anyway that is the general area.
You will need a O2 socket specific for the O2 you buy, and it would be nice to have a lift, or your going to be on your back. Unhook the connector and screw out the bad one and screw in the new one and reconnect the wire.
somewhere sometime ago, i read that...O2 sensors should give a voltage reading between 0V and 1V, and that if OBD2 reader does not tell u which sensor is bad, you just use a multi meter and check which sensor gives a reading that is extreme to one side.
something like that....in principal. so correct me if i am wrong.
#9
There is "anti-seize compound", "RTV", etc.. that are designed to be O2 sensor "safe". That is what would be applied to the new sensor.
But I would still do as Lugnut said, keep all chemicals away if at all possible. Obviously if it came with it, it should be ok.
Hope this helps
#10
Yeah, I'm talking about regular anti-seize or other chemicals. I was in a Z28 club several years ago and we rented a garage to do work on lifts. About a dozen guys replaced O2 sensors and put anti-seize on them because the exhaust systems were aluminum. EVERY O2 sensor died.
