Rear end fluid change on C230
Hey guys,
I have changed the rear end oil in my motorcycle but never on a car, do I just remove the lower drain plug and drain it and then fill it in the upper plug till I see the oil seep out. Would you suggest synthetic or regular. I am leaning towards synthetic.
Thanks all.
Trygve
Thanks all.
Trygve
RE: Rear end fluid change on C230
It's simple, and always, always remove the fill plug first, then the drain plug. If you drain it, and can't get the fill plug out, you are screwed. When I first buy an older car, I change it with regular gear oil, run it for a couple of weeks, then drain again and fill with synthetic.
liquid_drop
08-08-2007 04:19 AM
