problem with wipers not working
Old Sep 21, 2009 | 03:52 PM
kirbo's Avatar
Default problem with wipers not working
I am having a problem with my wipers , they all of the sudden stopped working . fuse is ok . i closed the hood and all worked accept the interminent spot . can anyone tell me is these a relay that may be bad ?
Old Sep 21, 2009 | 04:57 PM
chassis221's Avatar
if you have a car with the one wiper design usually the piston/shaft needs lubricated.
Old Sep 21, 2009 | 06:55 PM
kirbo's Avatar
i have a 2004 c230 sport sedan is here a relay for the wipers , and could you tell me were to get a schematic for the cars relays (what they do?????????)
Old Sep 21, 2009 | 07:08 PM
chassis221's Avatar
yeah there is a relay its in the driverside fuse box under the hood. but thats usually not the problem. what do you mean intermittant spot? so the wipers do wipe across the windshield a full cycle? or they stop in the middle of the glass. do they park normally? ive seen bad wiper switches/turnsignal stalk and also the motors go bad. play with the wiper switch switching from low, to high and to intermittant to check its function.
Old Oct 14, 2009 | 02:04 PM
sakutheking's Avatar
Default Wipers stopped working
I have similar issue with 2004 C230. Wipers suddenly stopped working, none of the 3 positions work. Only the one time sweep by pressing the **** at the end of stalk works, the one used for washer fluid.
Fuse is OK, I also tried by switching the two wipers related relays with each other, didn't help. Is it the wipers motor ? Please advice how to fix?
sparky999
Sep 21, 2013 09:02 PM
leemegg99
Mar 13, 2013 12:12 AM
PaulBox
Jan 15, 2013 04:55 AM
c-class fan
Nov 16, 2009 12:35 PM
CLK500KID
Apr 8, 2008 07:04 PM
