OBD codes...anyone know these?
Just scanned with OBD scanner (due to check engine light). Does anyone know what could be some of the possible causes?
VIN: WDBHA28E8TF469787
Year: 1996
Manufacturer: Mercedes-Benz of North America, Inc.(MBNA)
Make: Mercedes-Benz
Model: C Class
Engine Type:L6, 2.8L (173 CID)
Tranmission:Automatic
Trim Level: C280
License Plate: 12345
Mileage: 153780
=== Stored Error Code(s) ===
Error Code: P0170
Possible Causes:
Error Code: P0505
Possible Causes:
Error Code: P1700
Possible Causes:
Error Code: P0441
Possible Causes:
Freeze Frame Information:
1. DTC for which Freeze Frame was Stored - P0170.
2. Fuel System 1 Status - Closed Loop.
3. Fuel System 2 Status - Not Supported.
4. Calculated LOAD Value - 25.88 %.
5. Engine Coolant Temp - 194.00 °F.
6. Long Term Fuel Trim - Bank 1 - -7.81 %.
7. Intake Manifold Absolute Pressure- 13.62 Inhg.
8. Engine RPM - 736.00 Rpm.
9. Vehicle Speed Sensor - 0.00 Mph.
Monitor Information:
1. MIL - ON.
2. Misfire Monitoring - Complete.
3. Fuel System Monitoring - Complete.
4. Comprehensive Component Monitoring - Complete.
5. Catalyst Monitoring - Complete.
6. Heated Catalyst Monitoring - Not Supported.
7. Evaporative System Monitoring - Complete.
8. Secondary Air System Monitoring - Complete.
9. A/C System Refrigerant Monitoring- Not Supported.
10. Oxygen Sensor Monitoring - Complete.
11. Oxygen Sensor Heater Monitoring - Complete.
12. EGR System Monitoring - Complete.
Thanks for any help.
James
Year: 1996
Make: Mercedes-Benz
Model: C Class
Trim Level: C280
Mileage: 153780
Error Code: P0170
Possible Causes:
Error Code: P0505
Possible Causes:
Error Code: P1700
Possible Causes:
Error Code: P0441
Possible Causes:
1. MIL - ON.
James
RE: OBD codes...anyone know these?
James>
try: www.obd-codes.com
Everything you want to know is on that site. You will find all your codes except the P01700, and I think that one is
"manufacture specific", because I can't find it on that site. But, there are so many sites if you GOOGLE search OBDII codes, I'm sure you can find something.
So, the P0170 is a fuel trim (bank 1) problem
The P0441 is the Evap. Emission System and incorrect purge flow (be sure gas cap is sealed!)
The 505 is the idle air speed control system
Hope this helps. You will find that for each of these, there are several possibilities as to the fix.
Dolce Blonde
11-16-2007 02:55 AM
