New battery and now the windows don't work right
Had to change the battery last night. The radio wants a code, of course, which doesn't seem to be the one in the manual, but that's another story. This morning, I noticed the windows don't work right any more. The first position on the switch will move the window up and down until I let up on the switch. The second position, which used to run the window all the way up or all the way down, now does nothing. Is this normal? (This is a 2000 C230.)
Your windows are OK. After battery has been reconnected, the electric windows and sunroof closed positions must be re-programmed by closing the windows and sunroof, and holding the operating switch in the closed position for a few seconds. Next time, before you change battery make shure that all windows are up and sunroof closed and then do as I already described.
By the way, the radio code appears on a code card, not in a owners manual. Only MB dealer can help you out. |
Originally Posted by platonmind
(Post 131700)
(Post 131700)
(Post 131700)
Thanks again. The windows were the more annoying thing, actually. |
