MAP sensor location
Old Nov 3, 2011 | 05:45 PM
gcalbenzman's Avatar
Default MAP sensor location
Can someone please help me locate the MAP sensor on my 2000 Mercedes Benz C230? I am getting a CEL and the code says check MAP sensor. I know where the MAF sensor is located but I now need to check the MAP sensor. I have looked all over and can not find it. I would be nice to have a picture or at least detailed specifics on location. THANK YOU!
Old Sep 21, 2013 | 07:26 PM
hgslayr's Avatar
On my 2006 C230 Kompressor its located just inside the screen when you remove the air filter..Its a little arm that hangs down.. Be careful to not mess with it, Very delicate ad very expensive if damaged...Go to Autozone and get a can of MAF sensor cleaner spray and try cleaning it..If you have a K and N air filter, the oil from the filter can foul the sensor and sometimes can ruin it...Thy cost around $800 to have the dealer replace it...
Nutty
Sep 11, 2011 10:58 AM
1997c280
Mar 17, 2011 08:06 PM
rbjb99
Feb 8, 2011 01:06 AM
BlueSilver
Oct 27, 2007 08:32 PM
matt4x4
Jan 26, 2006 11:57 AM
