Low Beam Bulb Replacement on 2005 C240
My driver side low beam is out and I cannot figure out how to get to the bulb. I've searched the forum and found a bit of info but it hasn't helped. The only thing I can seem to budge is the rubber that surrounds the headlamp casing, which has three clips on top of the casing.
Can anyone please help? The more detailed the better. Thank you!
Found a diagram in the manual. I got the cover off but cannot get the bulb out. The manual says to pull out the electric plug, then twist the bulb to remove. I cant get the electric plug off. I pull but it wont give. Anyone have any ideas? Any help would be appreciated!
05C230Komp
12-25-2006 04:47 AM
