LFT Rear Window fell into door HELP
My Daughter shut the door a little hard then KLUNK the window fell into the door ?
The mechanism still operates up and down It must of came off track?
Is it hard to pull off the panel w an airbag?
Can someone help or forward me to a link or somthing
The glass is held to the sliding mechanism (regulator) by a piece that obviously broke.
That's why the regulator mechanism still goes up and down but the glass doesn't.
Depending on the model of the car (there are a million different parts for these), have a reputable
glass shop take the panel off and replace the broken piece or repair it if they can. Usually, the
attaching piece is broken, but in some cases, the piece just came off the glass. You can't tell until
you pull the panel off. I would let a glass shop or authorized garage do this job if it were mine.
Too much at stake. Just my opinion.
