I have a 2001 C320
I have a 2001 C320
I have new fuel pumps and filter, new throttle position sensor, new pedal position sensor, new cam sensor, new crank position sensor, new mass air flow sensor and now the car will not even start. My original problem was that the car would run but when it was hot and i cut it off it would not start until it cooled all the way down. Also at times the car would not take gas very well on the highway. I could punch it and it took a few seconds for the engine to catch up. I have cleared all odb2 codes so the check engine light is not on. ????????? Also I hear the fuel pump running when i switch the car on but my fuel pressure guage gets no pressure is it possible that my new fuel filter is stopped up?
Update time: fuel filter was stopped up put a new one on and now car will run and I get 60psi on the fuel rail
However the car will not take gas. I can press the pedal and the car will rev to 2500 rpm and no higher even if I floor it. Now no check engine light is on and have had the catylic converters checked
prospeedauto
07-14-2015 10:19 AM
Olidrummer1
11-19-2010 07:58 AM
prospeedauto
11-22-2008 02:23 AM
