Help !!
Thanks for your response, i will check the fuses again. However the problem started with the indicators and wipers working occasionally. If its a fuse then they wouldn't of worked at all would they? Also the ESP warning light as come on.
you could need the fix for the steering column harness repair . new harness get solderd in ....that could be the esp light. could just be a bad steering column module itself. the wipers and signals could be the turn signal stalk itself... you need to have codes ran to see what codes you have.
mlmrk
09-04-2014 07:00 PM
siliko
04-12-2008 06:51 PM
