HELP.....
Old Jul 14, 2006 | 04:16 AM
BadBenzBoyz's Avatar
Default HELP.....
How do you remove the entire ashtray [] ..., its 1997 MBZ C230
Joel
Old Jul 14, 2006 | 04:22 AM
sleepwalker's Avatar
Default RE: HELP.....
[IMG]local://upfiles/1/D3610DDA27154D2990A47602EB8BC1F3.jpg[/IMG]
[IMG]local://upfiles/1/A29DF399F1B64C14B25DBCBCD96A9094.jpg[/IMG]
Old Jul 14, 2006 | 12:14 PM
drblank's Avatar
I don't know if your ashtray is the same as my 2000, but here is what I did to remove my ashtray assembly.
Pull off the ring around the gear shifter. Then prey, carefully, the plate around the gear shift with a flat head screwdriver.
Then there is a little plastic tray right underneath the ashtray. Pull that out.. No screws.
Then unscrew the two screws that hold that little cubby above the ashtray and pull that out.
There are two little plastic screws at the bast of the ashtray. Unscrew those and make sure they don't fall down into the transmission area. :-)
KEEP THOSE SCREWS!!!!
David
Old Jul 14, 2006 | 12:18 PM
drblank's Avatar
does anyone have the part number for the plastic screws that hold the ashtray in?? I lost one and the dealer can't find the part number on their parts system.... Real pain the rear...
thanks
Old Jul 14, 2006 | 12:19 PM
drblank's Avatar
I lost one of my screws.... :-)
Old Jul 15, 2006 | 02:24 AM
sleepwalker...thank you very much
Old Jul 15, 2006 | 05:33 AM
you're welcome.
mlmrk
Sep 4, 2014 07:00 PM
Gunsmoke337
Jan 5, 2010 11:38 AM
siliko
Apr 12, 2008 06:51 PM
w_white
Aug 30, 2006 09:02 AM
legenesepimp
Nov 4, 2005 01:36 PM
