Headlight issues
Hello all, new to the benz world. My wife just bought a used 2007 C230 sport from a dealer, without the users manual. Nice car but the headlights point in opposite directions, like Marty Feldmans eyes, for the old timers. Anywho the carfax was clean of accidents and on first look, no adjustments for the lights can be identified by my ignorant eye. The left headlight points up, the right points down. So my question is, Is this an easy fix, or does this go to the dealer for reapair? Could someone have replace the bulbs and not install them properly? Any Help will be most appreciated.
could just be that the headlight bulb is not installed correctly. alot of times people try to change there own and dont actually get them installed the right way. they must be sitting flush in the housing or else the clip to hold in the bulb wont latch into place...maybe the headlamp assembly is broken someplace or could just need to be aimed
Consider yourself lucky.
I was about to post a question about whether or not you had the bi-xenons and that it was possible that something was wrong with the self leveling system. That's what I'm going through and believe that I may have fixed it myself.
Thanks for the posts. I have been trying to figure out how to adjust my headlights as well. I have the EXACT problem, on the the EXACT model. My driver's side needs to come way down, and my passenger's side needs to go way up. Could you go a bit more in detail about the location, and the procedure of the headlight adjustment bolt? Thank you very, very much!
