-   -   Fuse 8 in trunk W203 -06 Sedan (https://mercedesforum.com/forum/mercedes-c-class-10/fuse-8-trunk-w203-06-sedan-50738/)
mikael-155 Feb 22, 2012 12:57 PM
Hi all, some advice should be wonderful.
Idicators:
1. Low range on remote, only IR work I assume
2. Bad reception on FM
3. Blown fuse 8 in trunk
Received ideas:
Replace rear window (short cut in wire)
Broken amplifier for antenna
Short cut in signal horn for the alarm
Take it to the old car dump...
I really hope someone have a good trouble shooting track here, I don't want to put all my summer holiday savings in the MB garage account if possible.
chassis221 Feb 22, 2012 01:10 PM
replace fuse 1st.. should get remote operation back and fm back.
mikael-155 Feb 22, 2012 02:10 PM
Hi, thanks for the tips, that was my first thing to do but as soon ignition was on it blow.
Assume that I need to select the worst option and hand it in, and just be happy than they handover the bill..
chassis221 Feb 22, 2012 02:14 PM
if your car a hatch back? coupe? i see you said its a sedan, ive seen a wire harness around the rear window rubbing on some metal clips and shorting out causing the fuse to blow. youll have to remove the plastic trim around the window to see the harness. since you have a sedan im not sure of the cause. what amperage is the fuse?
mikael-155 Feb 22, 2012 02:19 PM
It is a 7.5 A fuse, I'm from Sweden, that is harness? And yes it is an Coupe or Sedan as we say.
chassis221 Feb 22, 2012 02:22 PM
if its a 2 door car. ive seen the harness cause that problem, if you have a 4 door car...im not sure. Sorry.
does the panic alarm work when holding the panic button on the remote? could be a bad alarm siren too. you most likely have something shorting out.
mikael-155 Feb 24, 2012 01:42 PM
SOLVED
Hi all, I have now solved it, it was a short circuit in the device behind the plastic protection in the front right wheel housing, just disconnected the cable and stored it behind the cover.
Both key and radio works fine now. After installing new fuse of course.
myfreeaudi Jul 25, 2012 06:59 PM
I have been struggling with the same symptoms. I was ready to take it to a local shop, when I came across this thread.
Replacing the alarm siren restored my remote control and the alarm works. The FM reception also is better.
Many thanks for the advice.
John
:D
tomard69 Sep 15, 2017 01:46 PM
any pics of where the alarm siren was disconnected to test if that is where short is?
PelicanParts.com Sep 15, 2017 04:33 PM
If anyone is having trouble with their W203, please take a look at the link below to our site's DIY tech articles. We're happy to answer and address any questions that you may have.
Mercedes-Benz C-Class W203 (2000-2007) Technical Articles – C320 E320 ML320 CLK320 SLK320 – Pelican Parts
