Front Parklight On and Off
Hi Guys,
My C240's malfuntion light will go on saying that the Front Left parklight is off. But after driving for a while, and restarting the car. The malfuntion light is off and the light is working again. Is there an electric problem? Have anyone encounter this problem before?
I don't have factory warranty anymore but does have the extended warranty with AUI.
Any help or advice will be great. Thanks.
Sam
Sam
RE: Front Parklight On and Off
While the engine is running switch every possible light on, then the malfunction will probably show. It should tell you the bulb is faulty - hence replace it.
If you have the W203 from 2001 C Class, then turn the light switch to manual headlights - low beam.
Then go and look into the lens.
Best of luck.
Best of luck.
ORIGINAL: SamChan
Hi Guys,
Sam
Hi Guys,
Sam
Open the hood turn all the lights and try to check whick one is lose.
arnottdoug
03-04-2015 12:33 PM
arnottdoug
03-04-2015 12:30 PM
fastmike99
10-28-2006 04:21 PM
moonbike
10-06-2004 10:22 PM
