Engine Noise w/ rough idle HELP!!
I'm not sure what this is or is caused by. I have had this 2004 C230K for about 2 weeks. One day I started it and it wouldn't idle smooth, other than that it ran fine. Gave codes of bank 1 lean and misc engine misfires. Took it in. They said intake leak, and some hose and valve downbetween supercharger and block had a split in it.
Picked my car up and it ran great, AFTER I had to go buy a clamp and install it on the elbow from the supercharger that goes into the intake manifold. Go figure. Now after the car is warm, and I turn it off for an hour or so, when I restart it it has a hell of a rattle, idles at a low RPM and rough.
I took the car back in and they said that it is the A/C compressor going out. A/C works great. When the car does this I can turn A/C on or off it makes no difference. Rev the car up a little and the noise stops, then the car idles and runs perfect. Any ideas? On most cars the RPM do change some when you switch the A/C compressor on and off. Do Mercedes? Mine does NOT. Is there an easy way to up the idle a couple of hundred RPM's?
HELP!!!! I spent $1800.00 on it to get repaired prior to making the first payment!![:'(]
Other than that I absolutely love this car, and I've owned many many cars.
lashare
02-17-2011 08:16 AM
WaBenzer
08-26-2008 05:41 PM
