Emergency mode
I have a C200 CDi automatic which has done approx 118,000 miles of mainly motorway driving. In the last 2 weeks the car when put under any kind of pressure, i.e. accelerating hard, goes into emergency mode and loses power. It will still drive but there is no real thrust or normal acceleration. Switching off the engine and restarting gets the car back to normal operation temporarily until the next time I apply any pressure. This can happen at slow speeds as well as at high speeds. I've had diagnostics run on the car and no 'events' are showing up so the garage don't know what the fault is. They've tried replacing the air flow meter with a new one but that didn't make any difference. The last time this phenomenon happened was yesterday and this time the engime management system symbol lit up. This has not happened before. Does anyone have any ideas what the most likely cause of my problem might be? The car is just 2 months out of manufacturers warranty so I've been told that I will have to pay if it goes into a Mercedes garage. Any help would be appreciated as I need the car for business purposes and I don't want to drive it with this warning light on. My regular garage closed today for an annual holiday so I can't take it there. Thanks, John |
RE: Emergency mode
hi i have the same problem but in my case the asr lamp lit up when i throttle fast and some have told me that maybe its the throttle body thats is failing
but i dont know tomorrow my car is going to be tested in a car shop so i hope i learn more then i have a c280 95 mod |
RE: Emergency mode
I have a 2001 C320 (w203) - NOT Diesel..
Mine too has developed some crazy fault, driving normally its acceptable, if i start to use the 3.2 v6 power then it seems sluggish - with little thrusting power :D, then it will spin the wheels at 60mph!! WITH THE TRACTION CONTROL LIGHT BLINKING. :eek: After driving it hard the Engine maganement light will come on, and the exhaust emisions smell very strong like rotting vegetables. After a couple of days driving normally the light goes off, I was hoping its a MAF/MAS that need replacement, its a 2 minute job. [8D][8D] Done 146,000 miles, so i suppose this would be normal. Further more, I was over taking 3 cars and then a bus in the same line the other day, they were doing 26mph in a 40 zone!!! WATCH FOR THE THREAD.... I lost power to on coming traffic!!!!!! |
RE: Emergency mode
Hi again,
I've had my problem diagnosed as a P0034 Turbo dump valve failure. We're trying to get a new valve but what its replacement is going to cost is anybody's guess at the moment. Two friends of mine, one with an E220 (2004) and the other with an S Class have also both recently developed the same symptoms! John |
Diving on emergency mode
Originally Posted by johnsev
(Post 76436)
| All times are GMT -5. The time now is 03:39 AM. |
