CPS location on 94 c220
RE: CPS location on 94 c220
Hi
I think you will find it on the left hand side (looking forward) of the engine casing, near where it meets the clutch casing, at around the 10 o'clock position. Access from top of engine. The wiring plug should remove easily by squeezing its smaller sides. There should be one Torx headed bolt to remove, after which a screwdriver can be placed between the sensorcasing and its recess in the engine casing. Twisting the screw driver should be enough to spin the sensor slightly loosening it before pulling it to remove, pre-soaking carefully withWD40 or similar if required.
Longhaily
07-11-2007 06:04 PM
