CLK230 comp -trunk wont open,no battery
Morning/Evening gents, new to the site thanks to try advise
I removed the battery from the trunk to use it to jumpstart another vehicle, and by mistake closed the trunk while battery was out!!!!
The blade key only seems to go in 1/2 way and wont release the locking mechanisim.
What can I do?
Is there a way to repower the car from i.e. the lighter socked as i read on someones suggestion, or can you power the car from the hood motor compartment I know u can do this on a BMW? not sure if the merc has jumper terminals in the motor compartment?
Im a nit I know thanks for any suggestions LOL>
What can I do?
You should be able to find + jumper terminal in engine compartment. Should be protected with red plastic cover with sign "+ battery terminal" or so.
Trunk lock is not mechanical but electrical and turnning it in horizontal position will just disable mechanizam to be opened by remote or inside trunk release button.
Ok guy's thanks for the suggestions. What we ended up doing might help anyone else out the dwang , decided not to take the chance of powering up from the hood terminal.
We took out the first aid box on the parcel shelf, dismantle the box completely take the ball out one screw, and you see 2 cables underneath for the seat release mechanisim, put a vice grip to one cable twisted and pulled , it worked and released one seat. Then had to climb into the trunk to attach a battery. It turns out that the lock for the boot had been previously changed and was not keyed correctly hence the blade key would never work - I curse the SOB who did this may your fingers turn to fish hooks and a thousand flease infest your nether regions.
thanks and see you all later for the next drama episode.
ladyjo
01-22-2014 06:34 PM
dee2000
07-21-2011 07:43 PM
dgrover
09-03-2008 08:47 AM
