CD problems
Old Apr 14, 2003 | 06:02 PM
mseys's Avatar
Default CD problems
Hi, when driving with the car, suddenly the cd stops playing, the sound disappears and the counter is running. When changing to the radio, the sound is good, changing to cd, nothing happens</P>
Any ideas what's wrong. Bought the car second hand.</P>
</P>
</P>
Old Aug 19, 2003 | 02:25 AM
togles's Avatar
Default CD problems
I have had problems with my changer as well , when I hit the cd button it just said empty on the display. I ejected the cartridge and put it back in. Still nothing, a couple days later it just worked again??? Kind of quirky. I also have intermittant problems with the quality of reception on the receiver as well. Another problem that I had was that the auto volume adjustment depending on road noise did not work worth a crap. I had the shop turn that "Feature" off for me.
Old Oct 22, 2003 | 08:22 PM
Andrew's Avatar
Default CD problems
I have a question for the person that was having problems with the cd changer displaying empty. What was done to fix that and has it ever happen again. I have a C280 that is doing the same thing and I don't have a clue on how to fix it. </P>
Old Oct 24, 2003 | 01:09 AM
rsg4ever's Avatar
Default CD problems
u have two possibilities either your changer or radio is at fault.there realy is no way of telling wich one without trying a know good component,but with my experience i found the change to be at fault 51% of the time good luck
Old Nov 19, 2003 | 04:06 PM
scrateef's Avatar
Default CD problems
I've had problems with my changer twice now (2002 C320 sedan). Both times, the changer said that the CD magazine was empty (even though it wasn't). My dealer said that Mercedes Benz recommends replacing the changer when that happens, so I've had mine replaced each time. There's no cost involved, but it's a bit of a pain to be without my car while they switch out changers.</P>
Does anyone know if a new changer is available that will work with the Cs?</P>
Brian</P>
Old Nov 19, 2003 | 08:27 PM
Andrew's Avatar
Default CD problems
Now did they replace it for free because it fell into the catagory of a recall for thecar or is it your warranty that covered it. My car is a '99 and its warranty has expired. I hopeit is a recall so I can finally get rid of my CD walkman.</P>
</P>
Old Nov 25, 2003 | 06:34 PM
Freewilly's Avatar
Default CD problems
I have the same probelm with my 99 CLK 320, it shows "Magazine Empty", don't know who can fix this problem. I am checking on ebay to get a new one, it's looks very easy to get it replaced.<IMG src=smileys/smiley6.gif border="0">
Old Sep 22, 2010 | 08:03 AM
Dada's Avatar
Had similar problems with "CD Empty" on my C280. So opened the trunk, turned the dial on the CD Changer box to get the 12 disc pack out. Realized there was this mechanical CD retriever moving inside the changer, the empty space opposite from the 12 disc pack. Thought maybe some kind of mechanical malfunction so sprayed just a little bit of CRC-556 (penetrant) and it seemed to do the trick. Could be simple dust paticles causing poor electrical connections? Can't guarantee a 100% fix here but thought some of you may want to try it out. At least a reasonable attempt before spending to change the whole pack! Mine is back to it's expected normal state and working fine ever since!
Naki
Jun 25, 2009 02:13 PM
