C280 Oil Change & Plastic Cover
Is it true that under-body plastic cover has to be removed to access the drain plug?
RE: C280 Oil Change & Plastic Cover
yes, unless you cut a hole in it :eek:
Theres only like four 8-10mm bolts holding it on tho |
Most dealer drain the enginer oil from the dipstick, this is an approved Mercedes Benz way. I have have a pumpt and canister I got from www.griotsgarage.com for around $70 with shipping. The filter is on top of the engine, total cost is a lot cheaper then the $120 or so I paid at Mercedes.
ORIGINAL: fly_major_fly Is it true that under-body plastic cover has to be removed to access the drain plug? ORIGINAL: C280 wizard Most dealer drain the enginer oil from the dipstick, this is an approved Mercedes Benz way. The reason most dealers do it is because it takes less time, and time is money. Personally, I would never siphon the oil out of anyone's vehicle. When I do an oil change it gives me the opportunity to check everything else while I'm down there. That's just me though. |
| All times are GMT -5. The time now is 11:00 PM. |
