C280 (1996) ENGINE STALLS
ENGINE STALLS INTERMITTINGLY. APPEARS TO BE AT COLD START. NO CHECK ENGINE LIGHT WARNING. I HAVE CHANGED THE AIR MASS SENSOR/ FUEL MANIFOLD REGULATOR/ ENGINE TEMP SENSOR/ FUEL FILTER AND FUEL PUMP. PROBLEM CONTINUES
RE: C280 (1996) ENGINE STALLS
fuel pressure should fine now.
it can be some loose connection on input side such as crankshaft position sensor, ignition system, or fuel pump electricals.
check the fault codes.
