C230 transmission conductor plate questions
I'm having a problem with my automatic transmission (722.6) on my 1998 Mercedes-Benz Base Sedan 4-Door 2.3L 2295CC l4 GAS DOHC naturally aspirated, 250K miles. The transmission takes about 5 minutes to engage from 'Park' to 'Drive' (reverse works fine). Here is what happens: After putting the car in drive the transmission does not engage. So I sit with my feet on the brakes for about 5 minutes after putting the car in drive. During that time I could feel the transmission jumping like it wants to engage. Then after 5 minutes I can feel it (hard shift) into gear and it is ready to drive. Here is what I had done so far: Complete transmission fluid change 4 years ago, recently changed the connector plug to the transmission, since it was wet with fluid. This did not help solve the problem. Getting a P0700 code, which state a possible 'Conductor plate' problem. I would like to change the conductor plate myself, so here are my questions:
1-Do I need to replace or buy any new components parts (solenoids, shifts valves, etc) on the plate?
2-Do I have to change the transmission fluid, filter and gaskets, once I change the plate or can I use the old stuff again?
3-Do I need special tools to change the plate?
Any recommendations/suggestions?
Thanks.
John
Thanks.
John
Thanks.
John
Thanks.
John
