c220 1995 abs
Old Aug 31, 2005 | 06:16 PM
enfield's Avatar
Default c220 1995 abs
warning light for abs lights up for a few miles then goes out.any suggestions out there?
Old Aug 31, 2005 | 09:08 PM
C280's Avatar
Default RE: c220 1995 abs
did u take ur dash out to replace a bulb?. if not>
this can happen from jamed up seat belt latches, as the abs unit checks these. maby clean them with something like a bit of crc in the plug, and blow them out with a air compressor, this could be your problem
Old Sep 1, 2005 | 11:52 AM
enfield's Avatar
THANKS FOR YOUR SUGGESTION RE ABS LIGHT.HAVE CLEANED AS YOU POINTED OUT AND ALSO CLEANED MULTIPLUG CONNECTOR ON ABS UNIT .WILL LET YOU KNOW IF IT WORKS.DUE TO GOOD WEATHER AM USING MOTORBIKE FOR WORK AT PRESENT THANKS AGAIN FOR YOUR TIME---GRIFF---
Old Sep 1, 2005 | 09:52 PM
C280's Avatar
There can also be a plug under the front seats than can come unpluged from one thing or another.
So move both your front seats right foward or backward and cheack out the cable under there and make sure everything is pluged in.
Watch out for CAPSLOCK also when posting ;-)
Old Sep 2, 2005 | 04:30 AM
dondas's Avatar
Just curious, C280, could you be confusing this with an SRS light coming on, because I don't understand how the seatbelts will make the light come on for the ABS system. Please excuse my ignorance and enlighten me.
Old Sep 2, 2005 | 06:09 AM
C280's Avatar
Shyte,
I just got owned :-(
the amount of times i ***** those to little acronms up
(mental note: abs=anti lock brake system)
i am sorry for making your **** around with that man.
but u know now what to do if ur srs light comes on :-(
Old Sep 2, 2005 | 06:20 AM
sleepwalker's Avatar
it happens to me many times too.
anyway, his problem could be as simple as speed sensor or different tires.
Old Sep 2, 2005 | 08:42 AM
dondas's Avatar
At least his seatbelts are nice and clean now. It's all about safety.
Old Sep 2, 2005 | 10:38 PM
  #9
C280's Avatar
haha :-) cheers guys
Old Feb 8, 2006 | 05:40 PM
  #10
gabbyroy's Avatar
Default C220 96 model
hi guys,
I own a C220 96 model. I took out the airbag module inorder to balance the steering wheel without disconnecting the battery. Later on when I was done and reconnected it the SRS light comes and stays on. Any help in resetting it. Thanks
