-   -   C0034 Code (https://mercedesforum.com/forum/mercedes-c-class-10/c0034-code-58034/)
cebuhasher Oct 26, 2017 04:39 PM
C0034 Code
had multiple warning lights come on. EPS, ABS, EPS off, and engine light. pull a C0034 code that indicated that right front speed sensor was bad. replaced that sensor but I cannot clear the code in the vehicle. all warning lights still come on and the Attention Asst is inoperable. any ideas?
PelicanParts.com Oct 26, 2017 05:44 PM
Hello and welcome to the forum! What model/year is this in regards to?
cebuhasher Oct 26, 2017 06:30 PM
yeah that was silly of me to leave that out. 2012 C250
labrewer1 Mar 10, 2021 03:53 PM
I had this problem on our 2014 Mercedes GLK350. I ran through the various possible causes that I saw on various Mercedes forums. I had just about decided that I needed to replace the right front speed sensor. Just before I got around to replacing it my wife disengaged the override window switch. It is a switch just below the window switches on the driver side door. When the switch is engaged there is a red light. The other window switches are disabled. When she disengaged the switch the check engine light went out, all the ABS and stability lights went out. The cruise control works again. In short the car is back to normal. Who would have thunk that this switch had anything to do with ABS.
labrewer1 Apr 2, 2021 11:45 AM
It was normal until yesterday. The same symptoms appeared. I pulled the code, C0034, came up again. I will start akk over. The first thing I checked was the window lock. It was not engaged.
