A/C is random
Last summer my A/C burned out so I had the whole condenser/etc. unit under the hood replaced. From that point untill today the A/C blows cold, but only 75% of the time. It randomly shuts off for a period of time, and will then come back on. Im wondering if this is effected by air flow or the temperature outside? -Evan |
RE: A/C is random
Is your engine under load alot, ie fast acceleration, up hills, passing etc. These conditions will shut down the compressor for a few seconds. The AC in my C class is effective by outside temps to a certain extent, if it is say 65 degrees F out and I want to turn the AC on I have to set the HVAC below 65 degrees F so the AC does come on. Or as always there could be a sensor or a temp control situation in the system? Sometimes I am baffled by what our cars do. Yesterday I went to start it and turned the key tothe start position and nothing, I turn it back and took it out waited a couple seconds inserted ( God that is a sexy word inserted) and it kicked right over. Try to figure
RE: A/C is random
Yeah, im an agressive driver, but this usually happens when im just chillin, and it hapens for more then 5-10min at a time when it does shut off.
When I said outside temperatures, i meant, if its 95F and Humid or im in traffic and its hot out, will this shut it off? |
RE: A/C is random
ORIGINAL: evillwock Hi, Last summer my A/C burned out so I had the whole condenser/etc. unit under the hood replaced. From that point untill today the A/C blows cold, but only 75% of the time. It randomly shuts off for a period of time, and will then come back on. Im wondering if this is effected by air flow or the temperature outside? -Evan Cheers, TJ |
RE: A/C is random
When the a/c shuts off, is there a big change of temperature inside the car?
RE: A/C is random
Its somewhat of a change. It doesnt blow "warm" air, its just not cold, more off-cold 20F warmer.
Its a 1997 C230 with a Climate Control Unit (the digital one with the screen) |
RE: A/C is random
I know this is a silly question but when you have the a/c on, is it on automatic or manual? On my 95 c280 i can turn the automatic climate control off and have the a/c constantly on. I'm not sure if that helps at all.
RE: A/C is random
I switch back and forth, I just recently started doing it manually, so I can choose what vents it comes out of, but there really is no manual as you set the temperature and it automatically trys to achieve that.
RE: A/C is random
I have climate control on my 99 and use it manual and auto, and the only time I've had the compressor shut off, is under heavy load, so I think you got a problem with a relay, sensor etc?
RE: A/C is random
must be...
