A/C is random
Old Jul 6, 2005 | 04:20 PM
evillwock's Avatar
Default A/C is random
Last summer my A/C burned out so I had the whole condenser/etc. unit under the hood replaced. From that point untill today the A/C blows cold, but only 75% of the time. It randomly shuts off for a period of time, and will then come back on.
Im wondering if this is effected by air flow or the temperature outside?
-Evan
Old Jul 6, 2005 | 05:16 PM
C280 wizard's Avatar
Default RE: A/C is random
Is your engine under load alot, ie fast acceleration, up hills, passing etc. These conditions will shut down the compressor for a few seconds. The AC in my C class is effective by outside temps to a certain extent, if it is say 65 degrees F out and I want to turn the AC on I have to set the HVAC below 65 degrees F so the AC does come on. Or as always there could be a sensor or a temp control situation in the system? Sometimes I am baffled by what our cars do. Yesterday I went to start it and turned the key tothe start position and nothing, I turn it back and took it out waited a couple seconds inserted ( God that is a sexy word inserted) and it kicked right over. Try to figure
Old Jul 7, 2005 | 10:49 AM
evillwock's Avatar
Yeah, im an agressive driver, but this usually happens when im just chillin, and it hapens for more then 5-10min at a time when it does shut off.
When I said outside temperatures, i meant, if its 95F and Humid or im in traffic and its hot out, will this shut it off?
Old Jul 7, 2005 | 11:12 AM
SL600_Cruzin's Avatar
ORIGINAL: evillwock
-Evan
Depends upon what kind of car are we talking about. Do you have manual A/C ? Climate Control ? Etc... Please giv eus some more info and we may be able to help.
Cheers,
TJ
Old Jul 7, 2005 | 11:16 AM
eurotrashboy's Avatar
When the a/c shuts off, is there a big change of temperature inside the car?
Old Jul 7, 2005 | 11:29 AM
evillwock's Avatar
Its somewhat of a change. It doesnt blow "warm" air, its just not cold, more off-cold 20F warmer.
Its a 1997 C230 with a Climate Control Unit (the digital one with the screen)
Old Jul 7, 2005 | 12:24 PM
I know this is a silly question but when you have the a/c on, is it on automatic or manual? On my 95 c280 i can turn the automatic climate control off and have the a/c constantly on. I'm not sure if that helps at all.
Old Jul 7, 2005 | 12:29 PM
evillwock's Avatar
I switch back and forth, I just recently started doing it manually, so I can choose what vents it comes out of, but there really is no manual as you set the temperature and it automatically trys to achieve that.
Old Jul 7, 2005 | 02:23 PM
  #9
I have climate control on my 99 and use it manual and auto, and the only time I've had the compressor shut off, is under heavy load, so I think you got a problem with a relay, sensor etc?
Old Jul 7, 2005 | 02:58 PM
  #10
evillwock's Avatar
must be...
