A/C Compressor failed
Has anyone had their A/C compressor fail on a 1999 C280? I can;t believe it. I thought I had just run low on charge. I had AC in the morning at at noon nothing. It just stopped. Took it to dealer and find the compressor was shot! THese things are ridiculously expensive. I think the AC compressor for home central cooling is cheaper. This thing was $1000.
OK I am done now. But has anybody had this. The tech said it was pretty rare.
RE: A/C Compressor failed
I replaced the entire A/C assembly last summer (compressor, etc.) and cost me close to $1300. The A/C had been working fine, then all of a sudden it started making a grinding noise, then a day later it was shot.
After everything is replcaed, it still doesnt work when its really hot out, its bi-polar it seems, and no one knows how to fix it.
ORIGINAL: sleepwalker
sometimes it make sense to get those extended warranty thing. same thing as going to casino once.
Burned light bulb in the cluster ($170), rust stains on the headliner (got quote of $900 just to inspect it), cracked molding on the tailgate.
Since you are'nt on warranty, have you considered a competent independent garage? On a small repair I priced, an independent garage was less than half the price of the dealership.
Regarding extended warranties: I've looked into several and decided unless one is exclusionary (listing the parts NOT covered, while everything else is covered-similar to "bumper-to-bumper) then the company can make the case that a non-covered part caused the problem and therefore they won't pay. That said, most warranties I considered covered the A/C compressor. But will they use new OEM parts? Probably remaned parts.
#9
I had it done at a Mercedes garage. I dont know the exact ammount, but I had it all replaced.
Im not sure if they coded anything? Its just very random, and doesnt like hot/humid & extra sunny weather.
#10
well, compressor do go out a lot, mine went out and i replaced it fort 270 dollars used ofcourse and the next day it went out again, and problem was with the radiator the tubings were all dirty so i had this medicine put it for 12 hours to clean, then the whole system was dissasembled and cleaned...thank god i didnt have to change my radiator, i put in another compressor changed the ac tube with a new one, and now, filled it with gas...and now it works as a charm.....cost of all this was 350 dollars....estimated cost at dealership was 1350 dollars...saved a lot
1999, 280, ac, aftermarket, c280, central, codes, compressor, compressors, cooling, cost, failing, home, mercedes, recharging
