C 230 VIBRATES AT IDLE, ONLY ONCE A DAY???
Old Oct 30, 2008 | 09:36 AM
  #11
Goldengirl1's Avatar
Default RE: C 230 VIBRATES AT IDLE, ONLY ONCE A DAY???
I had a very similar issue and tried most of the same things that you did and after they replaced the spark plug wires, the issues stopped.
Old Feb 18, 2009 | 11:26 AM
  #12
LORE BENZ's Avatar
how many plug wires for this C 230, is it easy for me to replace them myself?
should i replace coils as well?
When do you know when wire harness goes, symptoms to look for, and why so expensive?
I have noticed that acceleration is a little sluggish, got to find decent independent mechanic.
Old Feb 18, 2009 | 11:54 AM
  #13
keith sikora's Avatar
Default rear speakers
How do you replace driver side rear deck speaker on my 1997 c-230 music crackles on low volume the system appears to not be a boses
thanks for any help
Old Feb 19, 2009 | 11:44 AM
  #14
ivanho's Avatar
hi never really had this problem but the od time mine has stalled or started to race was when the tank has low fuel and all the crap comes down the pipe the engine either stalls or reves up to stop it from stalling my need a petrol filter change or it could be somthing as stupid as the throttle cable sticking check this first will save you a few quid if its ust that
Old Feb 21, 2009 | 12:16 AM
  #15
alfanathan's Avatar
i have similar problem wit my c180 compressor i know yore Paine Mayne is idling and ratling also lost a bit of power and i replaced my supercharger,advised by my ******** mekanik
Old Feb 22, 2009 | 08:05 AM
  #16
LORE BENZ's Avatar
I now have 120,000 miles on 98 C230.
IDLE STILL rough in DRIVE and less in park, still idle fluctuation when cold only at first stop and idle. No power loss at speed. I changed MAF AT 40,000 miles, throtle boddy clean at 100,OOO MILES.
I WANT TO SEE DIY PICS OF SPARK PLUG CABLES change ON 98 C 230 AS CULPRIT OF IDLE FLUCTUANCE and possible motor mounts for vibration.
any constructive ideas by anyone is appreciated??
Old Feb 25, 2009 | 11:00 AM
  #17
LORE BENZ's Avatar
Any further ideas are welcome?
Old Feb 26, 2009 | 11:35 AM
  #18
csapi's Avatar
if ur idle is higher then suppose to be then u just need to put the ignition on and do nothing else. wait for a 2-3 minutes. this is the way how u can teach ur throttle body for the new gap. after ur idle speed will be good then ur transmission will be smooth again.
Old Mar 30, 2010 | 11:47 AM
  #19
halfthy's Avatar
Default Ideling and stalling
Try replace Crank shaft sensor. It willl eliminate the issue
Old May 12, 2010 | 09:42 AM
  #20
mikecruz's Avatar
Halfthy!!! My god where were you 5 years ago! That fixed 90% of my problems with the rough idle and acceleration shuttering I was experiencing.
https://mercedesforum.com/forum/mercedes-c-class-10/98-c230-rough-idle-4019/
When my 98' c230 does start to shudder, the only fault code that comes up is 'P0304' "Cylinder 4 Misfire Detected" so I'm thinking I might replace the ignishtion coil, but still unsure if that will completely fix it.
Either way replacing the Cam Shaft Sensor was a noticeable difference.
Thanks Halfthy!!!
btw I'm at 139,000 miles now and still running. can't believe what a beast this little four banger is.
