Brake Pad Life???
Thanks. Dealer said given the engineering of the car (the way brakes are used) the pad life is shorter than normal (20-30k miles vs. 40-50k for other cars). Doesn't feel right but not sure (they are expensive to replace). In any case, thanks for the feedback!
I had new front pads at 23k miles and all four at 43K miles which was about a month ago. Mercedes pads are soft to start off with, and if you do a lot of stop and go, or hard braking, 20K is within normal ranges for front pads at least. I was told Mercedes brake distribution is 60/40 front/rear
Thanks for all the feedback. Just got the car back. Dealer took a good look at them this time and it turns out they are about 70% worn at 24K. So the problem I am having must be something else, as I originally suspected (a kind of abnormal jerking when I stop, happens infrequently, but has been noticable since ~18K). Thanks again!
Thanks for the reply. The problem is there is a kind of grinding noise and sensation when using the brakes. It happens irregularly,and there are no other apparent problems(like the brake pedal or steering wheel shifting about). The car had sat for awhile (around the 18K mark when the problem first started). Is it possible that the brake pad has made an impression on the rotor (rust imprint) that the pad is now grinding up against? Thanks!
A decent mechanic can measure the "run out" (warp) on the rotors. If it's just a rough spot, they should be able to "turn" the rotors to flatten it out.
With the pads 70% worn, I'd get new pads and get the rotors turned, if they're not too thin or too rough.
