asr/bas warning light
the warning light for the asr/bas system on my 98 c 200 lights up every now and then when i start the car,if i switch the engine off and start it again the light goes out...does anyone have the same problem or does anyone know where the sensor is for this system as it might just be loose or dirty...thanks in advance
all you have to change is the brake pedal switch.
here is the steps in changing th brake pedal switch. i had the exact same problem and when i changed it, it was fixed for good. Good Luck http://www.benzworld.org/forums/w163...light-fix.html
Kikoap
Jul 30, 2012 02:50 PM
Kikoap
Mar 27, 2012 10:37 PM
