anyone know how the radio comes out ?
BB- What year is your 220? It should be straight forward, remove the A/C vent trim ring from the center A/C vents, take out the ashtray release the 2 retaining clips that are tucked back behind where the ashtray sits(1 on each side), rotate your center A/C vents all the way up until they click past their normal maximum position so you can get a torx head bit in there to loosen the 2 bolts, then the center dash console should pull off giving you access to the 4 torx head bolts that hold the radio in.
cobbcfi
Jul 23, 2010 07:17 PM
