52 plate C220 Auto
Old Aug 30, 2011 | 04:08 PM
f7ash's Avatar
Default 52 plate C220 Auto
Hi. I have a bit of a problem, when I first start my car an put it in reverse their is no power at all when I put my foot on the excelorator, the revs stay on idol (900 revs) even if I put my foot right down. It also not responding straight away when I excelorate takes maybe 1-2 secs to respond. I have also just started getting the smell of fumes into the car, which is coming from the back of the engine. I've had the car for 4 weeks an the problem is slowly getting worse. Any helpers please. Been told it just could be the oil that needs changing.....
Old Sep 1, 2011 | 01:09 AM
JohnnyRaggs's Avatar
Not sure who told you just to change the oil but I would probably not seek automotive advice from him again. Is the check engine light on? Do you experience lag when taking off in drive? If you do, it could be the mass air flow sensor.
Old Sep 1, 2011 | 11:10 AM
f7ash's Avatar
no light on. an yes i do get lag
Old Sep 1, 2011 | 11:51 AM
Then I would put my money on a faulty mass air flow sensor
Old Sep 2, 2011 | 03:29 PM
f7ash's Avatar
I have just ad the cover off, an at the bass of the injector, it is blowing air out. So do I just need to replace the the injector or just the seals
Old Sep 2, 2011 | 03:33 PM
You can try just the seals first as it is the cheaper option, if that doesn't work then the injector should be replaced. Check for cracking where the injector sits when you have it out though.
dinesh.panchani
Apr 10, 2013 07:40 AM
WATERJET
Sep 8, 2009 02:11 PM
Fat Boy Slim
Jun 10, 2009 09:03 AM
broadbander100
Jun 12, 2007 03:10 PM
bakerman
Dec 2, 2006 04:31 PM
