240--Electrical system going a bit nutty
Have a 2002 C240. Took it through the car wash today as as soon as I exited, the instrument panel said a door was open. I stopped, opened and closed all doors, continued on my way. Two blocks down, same error msg came. Then, the dome light switched on for about 30 seconds, then turned off. When I could stop again, I opened/closed all doors, windows, trunk, sunroof, got back in car-- error msg came on again. So did dome light.
Also, usually, all doors will lock once I engage the transmission into drive and then all doors will unlock once parked and the driver door opens. None of this happens now. I'm worried. Any ideas? Suggestions?
RE: 240--Electrical system going a bit nutty
if you got multifunction steering wheel, set it from the menu.
JimMayor007
09-21-2008 01:27 AM
