2058-001 code from Mercedes Star diag
Hello all,
I have this prob which I cant solve for almost a year. Tried almost everything. If anyone had similar problem I would apreciated any comments. Mercedes W203.042 - 2003 year , 200 Kompressor, M271 engine Selfadaptation goes pass +1 every time. Once reset to zero goes up slowly straight away Fault code 2029-001 system rich and self adaptation faults Lambda 1 oscilating 950mV- 1050mV at idle Eliminated all leaks thru overpressure test, replaced breather pipes. Intake system is holding the pressure when system blocked at air mass meter using merc tool. Change upstream lambda sensor, change air mass meter. Fault for Lambda control keeps coming back upstream of TWC 2058-001 Checked all values again and self adaptation +1.9, and Lambda 1 again around 9++mV !!!!!!!!!! Why is my labda value showing low all the time. Pls help... Appreciate if u can email me your views. alex2942@hotmail.com |
hey Alex,
I have the same problem. C-class 200K exhaust valves in cilinder head were leaking, lambda sonde went up to +- 1200 mv but i cant get it higer. fitted an new katatysator (advice from bosch carservice helpdesk) but it had no effect. changed the lambda sonde's, fuel injectors, HFM, kombi valve(from EGR). there is no vacuum leaking. So if you solved it let me know, i'am about to wreck it. Thanks, Greetings Pim. |
Hey guys,
Have you found the problem? Same here, for more than a year I am trying to solve it with a lot of money spent and zero effect. Please reply, Thank you Andrew |
Originally Posted by Andrew Bassa
(Post 175191)
Hey guys,
