2005 C230 - License plate bulb light message
Old Dec 3, 2008 | 02:33 PM
sohails's Avatar
Default 2005 C230 - License plate bulb light message
I get "1 Message" in the car
leftlicense plate light not working. However I checked the bulb and it seems fine.
What else do i check?
How do i delete the message?
Thank you in advance for your help
Old Dec 3, 2008 | 02:39 PM
melloc230's Avatar
Default RE: 2005 C230 - License plate bulb light message
I had the same issue and replaced the bulb. My bulb was going on then going off. The filament looked ok but was going bad from what the service rep told me so the sensor would pick it up as needing to be replaced. Once I replaced the bulb the message went away and it's been fine.
Old Dec 3, 2008 | 02:50 PM
sohails's Avatar
Is the bulbbehind the front license plate to the left?
I am gussing it can be easily found and replaced? Anything I need to know.
Appreciate your quick response.
Old Dec 3, 2008 | 03:39 PM
melloc230's Avatar
Mine went off for the right side plate light. Same location right above the plate next to the trunk handle. You will need a small phillips head to remove the screws. I replaced both bulbs just incase. One lens cover came off quite easily but the other needed some help . Just leave one screw threaded just enough so you can pull slightly down to remove the lens cover.Real simple job takes like 2 minutes at the most to replace.
Old Dec 11, 2008 | 09:25 PM
sohails's Avatar
I went to autozone and they said they dont' carry the bulb. I would only find it at the dealer?
anyone knows where else i can buy this from.
any part # etc
thanks
Old Dec 12, 2008 | 12:08 PM
melloc230's Avatar
I got my bulb from Kragens Auto Parts. I got a pack for 2 for $6.00. Part number I don't know off hand but the parts person should be able to type it up in their system.
mcguirejw
Dec 24, 2014 12:36 AM
quattro100
Oct 7, 2010 07:33 AM
quattro100
Oct 6, 2010 08:52 PM
BenzoDJ
Nov 16, 2006 09:31 AM
par49iron
Jun 18, 2006 03:20 AM
