2003 C230 Headlight Problem
I have a 2003 C230 (K). I keep getting a "Check left lowbeam headlight" message on the dash, and it then will go away. This driver's headlight will work intermittently, sometimes no problem, then other times it's out.
I pulled the bulb, and the connection at the bulb appears clean. I'm wondering if it might be the switch, or something in the headlight assembly. I haven't seen anything to indicate there were any TSB's or recalls. Any idea what could be causing this? Thanks! |
RE: 2003 C230 Headlight Problem
Lat May,I had to have the passenger side "Headlight" socket changed since it started using too many bulbs and was exhibiting a burnt electrical smell. MB doesn't make a new socket or harness for the CL230 but miraculously a knowledgeable parts man realized that a headlight socket harness from an ML will fit perfectly.
Problem solved. It took an hour of shop time but I was getting the battery replaced anyway. |
