2003 C-240 4-matic Check Engine
Old 10-01-2010 | 10:47 PM
JatMat's Avatar
Default 2003 C-240 4-matic Check Engine
1st post, tried to search, but could not find a similar problem shown.
While idling, my check engine light came on, I scrolled through the dash menus to find malfunction one. "No Malfunctions" showed, I turned engine off for a minute, re-cranked, but light was still on. I plan to check for codes tomorrow, but if the computer is not reading a malfunction, will there be a code to reset.
Any Ideas anyone?,
Jim
Old 10-01-2010 | 11:25 PM
ontmiss's Avatar
When check engine light comes on you need OBD2 scaner to read codes
Old 10-02-2010 | 08:01 AM
JatMat's Avatar
That is what I was going to use, but, if the MB computer is not reporting malfunction to the dash display, will the code still print out?
Old 10-02-2010 | 09:47 AM
ontmiss's Avatar
Malfunnction dash display will never show you anything if error happens in ECU (emission control unit).
Old 10-03-2010 | 06:14 AM
JatMat's Avatar
I got the codes, said it was 3, but only showed two numbers, one was PO335 and the other was PO435, said it was a crankshaft position indicator circuit malfuntion, other was a very small emissions leak.
I had replaced the crankshaft position indicator a month ago, but do not know if the codes were cleared. At that time the dash was reporting the correct problem. Any way, I cleared the codes and so far so good. I wonder if the emission leak could have been caused by being behind an old truck blowing smoke in the drive thru lane? How do you find a "very small emissions Leak" ,
if the truck was not the source of the code?
nolen01
05-07-2015 06:58 PM
keithl1967
12-05-2011 07:10 PM
egil.folstad@gauldalen.no
09-03-2010 03:58 PM
MarkC320
09-28-2007 04:14 PM
mbct
05-23-2006 10:20 PM
Quick Reply: 2003 C-240 4-matic Check Engine
