2002 C320 Speedometer Needle
Good Day. I'm from the Canadian Prairies.On Saturday eveningit was -4 celsius aprox 25 F. The vehicle sat outside for aprox 6 hours. When I started it, the speedometer needle seemed to 'rattle' (up and down) and make a noise. I started driving it and then it stopped, speedometer needle seemed to work fine until I parked the vehicle and removed the key from ignition. Speedometer Needle started acting up again and rattled for about 10 sec and then it stopped.[/align][/align]While I was driving it, I didn't check the dash menu functions and see if the digital speedometer was functioning properly. On Sunday the vehicle was parked inside a garage overnight, started it in the morning and everything was fine.Vehicle only has 70,000 km, I'm the second owner and this is the 1st winter I've had it, 1st owner had the vehicle out east where weather is milder. I am Super surprised that its acting up in -4C weather because where I'm from it gets as cold as -40C (-40F) in Jan/Feb...So its going to be put through the extreme test this yr.
This is kind of bothering me, its in the back of my mind when is it going to happen again?And if it does what if it doesn't stop even if the key is out of ignition?Could it be the cluster?Is this serious? Suggestions?[/align]
