2002 c320 Solenoids questions
I am replacing all 6 solenoids. 2 solenoids have the following number:
2xA 1402770535
and the other one has the following number:
1xA 1402770635 (the bottom one from the picture)
Should I return the one that ends on 0635 and asks for a 0535 instead, I believe they sent one with the wrong number or it is fine if I install it like such. Keep in mind that the current solenoids (old ones) all 3 have the same number meaning they all are A 1402770535. I just want to make sure if is on to install the 0635 one or return it for the right one (0535).
Thanks in advance!
Fx7
2xA 1402770535
Thanks in advance!
Fx7
I previously used Akebono Ceramic pads on my E92 for low dusting properties - they were excellent Went to buy them for my F32 with 5k miles on the OEM pads/rotors (Brembo frt/Bosch rear calipers) & they do not make the full set for my application, so I went with the CoolCarbons - installed new rotors at same time as I wanted crossdrilled/slotted.
192.168.100.1 192.168.1.1
