2002 C240 power issues
Old Oct 26, 2008 | 05:41 PM
EvilZombieZ's Avatar
Default 2002 C240 power issues
I have a 2002 C240 that tends to die over night. I have installed a kill-switch attached to the battery so when I am done driving the car I can flip it and the battery will no longer drain. Anybody has any suggestion on what this could be? The car sometimes idle's rough when sitting at a stop sign or red light as well. Thanks in advance for any suggestions or help.
Old Oct 26, 2008 | 07:14 PM
chassis221's Avatar
Default RE: 2002 C240 power issues
if you have power seats it could be the seat adjustment control modules under the seats.. if the part number starts with a 203 then they should be replaced. if they have a 211 number then they are ok.
Old Oct 26, 2008 | 07:51 PM
Thanks, when daylight comes I will check them out. If they do need replacing what price range am I looking at for a set?
Old Jan 18, 2009 | 04:53 PM
davidanthony21's Avatar
2001 C240. Seat control module drains the battery in 2-3 days. I looked underneath the seat and found a bunch of plugs. 4 in the back and 2 or 3 in the front. Which ones do I disconnect? Someone mentioned here that you can splice a wire that is for keeping the seat control on after the car if off, and that should fix the problem. Either way I am completely lost. Any pictures of the steps needed would also help.
davidanthony21@yahoo.com
madderhatter
Apr 29, 2011 10:04 AM
PatArt
Jun 3, 2010 09:49 AM
alinux
Sep 26, 2008 01:01 PM
EricV
May 9, 2008 04:49 PM
EuroKRN
Dec 27, 2005 02:14 PM
